Re: Head Gasket Problem
Posted by Janicholson on September 03, 2006 at 20:03:30 from (66.173.50.44):
In Reply to: Head Gasket Problem posted by Patrick in Illinois on September 03, 2006 at 18:23:45:
If the core plug (they really aren't freeze plugs, they are used to get the sand out of the casting after the iron cools) in the back of the block is leaking (Antifreeze coming out of the bell housing) there is no other way to fix it than a split. Your C is leaking in two places for sure, The "O" rings at the bottom of the cylinder wet sleeves are toast, and need to be replaced (requiring the complete disassembly of the rod to crank connection, removal of the pistons and pulling of the sleeves. This is not hard in a wet sleeve engine, just wooden block kind of thing. If it has hours, why not put in a engine kit. At about $800 for all stuff including fluids and materials, it would go a long way towards great tractor. If the rear core plug is leaking, it needs to be pulled. At that point doing the mains and a new rear seal is the ticket. If it has low hours, or you are budgeted to just fix it minimally, and the core plug is OK, just "O" rings and gaskets might do. Lube the "O" rings with silicon grease, or dish detergent when installing the cleaned up sleeves. Be sure to put things back in the same hole, and in the same rotational location, and the pistons facing the way they were. The manual is mandatory for specs and process. Good luck JimN
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
