Re: Hard starting cub
Posted by El Toro on September 04, 2006 at 05:41:12 from (205.188.116.133):
In Reply to: Hard starting cub posted by scott#2 on September 04, 2006 at 04:32:25:
Pull the coil wire from the mag's cap and hold within 1/8-1/4" of a good ground and have someone to make an attempt to start the tractor. Be sure the kill switch is in the run position. You should have a hot blue spark when the engine is being cranked. You may want to use a pair of insulated pliers so you don't get bitten. If the spark is weak the points should be cleaned and adjusted to .013". Don't remove the mag from the tractor. You can use a point file or use 320 wet or dry that's folded over so it will clean both points. Then take a cotton swab dipped in alcohol and clean the points, do this several times. Then check for the spark again to see if there's any improvement. If it looks good reconnect coil wire to cap and try to start engine. The coil may be weak on the mag. Hal
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
