1066 Oil Leak
Posted by Rick in Ont. on September 04, 2006 at 07:08:58 from (70.53.99.185):
I have a 1066 that when started cold will leak oil from behind the steering wheel valve. If I turn the wheel lock to lock, leak will stop. I have had the cover off and of coarse it will not leak at that time. I have tightened all the steel lines and all appear to be in good shape. As I said the leak appears to be comeing from the back of that valve. This problem started after tractor was in to have T/A replaced. Does anyone have any ideas....Thanks Rick
