Re: 1066 Oil Leak
Posted by the tractor vet on September 04, 2006 at 07:28:57 from (75.24.11.52):
In Reply to: 1066 Oil Leak posted by Rick in Ont. on September 04, 2006 at 07:08:58:
The seal on the orbital motor is leaking and need to be replaced . Not a hard job tools required are a steering wheel puller snap ring pliers and a 1 1/18th scocket 2 1/4 x 6 fine thread bolts a couple flat washer and a 1/4th fine thread tap to clean the bolt holes out in the steering wheel . Pull the wheel remove the snap ring put the steering wheel back on with out the nut and give a sharp twist either way and it will pop the old seal out pull the wheel back off remove what ya see has to come out and replace same with what is in the kit cost is somewhere around 15 bucks. time requried to do this about 15-30 min.
