Re: Farmall A Pistons/Rings
Posted by Red Dave on September 05, 2006 at 16:27:25 from (66.109.237.22):
In Reply to: Farmall A Pistons/Rings posted by tyler cohrs on September 05, 2006 at 16:09:33:
It certainly sounds like you have a problem, but I'd suggest a compression test to confirm it before you sink a lot of dollars into it.
For a Farmall A, you can put 3-1/8 pistons and sleeves in it. That is 1/8 inch oversize. You can also get those in a high compression (stepped head) piston. The IH brand name for them is Fire Craters (if I remember right). Several other manufacturers have their own version of them.
I used Clevite 3-1/8, stepped head pistons in my B (same engine) with good results.
