Re: Farmall A Pistons/Rings
Posted by Red Dave on September 05, 2006 at 16:54:34 from (66.109.237.22):
In Reply to: Re: Farmall A Pistons/Rings posted by magman on September 05, 2006 at 16:39:08:
Magman, that is just not accurate. Pistons and sleeves will NOT make an A into a Super A. The Super A had the exact same 3 inch piston X 4 inch stroke that an A had. 113 cubic inches.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
