Re: Boring out an H
Posted by ChadS on September 07, 2006 at 18:45:34 from (66.228.96.131):
In Reply to: Boring out an H posted by Farmall'47 on September 07, 2006 at 17:46:25:
There is a 3-11/16 bore piston out there but I cant remember who has em at the moment,,, for a low gear puller, dont need any more than that for a engine if thats what you have in mind. 2.5 inches on the compression height for the H-350,,, optimum pin diamter is .875 or less to have room to offset the bushings enough to compensate if needed. Ive seen 175 ci engines in the mid 50's in power,,,, thats with a 350 head, cam, carb and manifold. ChadS
