Re: 1466 Doesn't Want to Start Unless it Gets a Li
Posted by Ted in NE on September 07, 2006 at 20:46:26 from (65.39.111.117):
In Reply to: 1466 Doesn't Want to Start Unless it Gets a Little posted by Mario2 on September 07, 2006 at 18:46:32:
Do you get white smoke when cranking it while it does not start? The injection pump has an oil pressure operated overfuleing device. If it sticks in the run position, will be very hard to start. Can usually be freed up. Is located under the top cover on the pump. Just something that can cause your problem.
