Re: Twine knot basic
Posted by Janicholson on September 08, 2006 at 13:29:57 from (199.17.6.122):
In Reply to: McCormick 45 square baler posted by Ben Ford on September 07, 2006 at 21:09:18:
You may know (others not) Twine knot:
To make a twine splice that will (usually) pass through a knotter without grief, try this.
With two clean square cut ends of the twine (one the end of the old ball, and the other the new ball) make a normal first knot like tying your shoes. Then take the ends and fuzz them up by seperating the strands and rolling them until they are frayed back about an inch and a quarter. Then push the two ends together meshing the strands so that they overlap each other one full inch, and have integrated (kinda like folding your fingers together). Rolling the resulting splice between your fingers to squish it small is the next step. Last is to itghten up the first knot, while holding the splice together, until a good portion of the splice is inside the first knot. Then pull the knot tight. This knot is not much bigger than the twine, and unless it happens to get into the knotter, it will pass through the system. It is as strong as the twine, and works wonders. Practice on some extra twine while relaxing (it kinda looks like macreme! JimN
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
