McCormick 45 square baler
Posted by Ben Ford on September 07, 2006 at 21:09:18 from (205.188.116.133):
I recently bought this old baler and went to my hay field today with it. It makes a bale just fine. Problem is I should have studied the twine route into the tie area. As the old twine was rotted and broke right off the bat.
Any info that you can give me on how to route the twine will be appreciated. Is there a sketch anywhere out there?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
