Oil Pressure Results
Posted by BOBCD on September 08, 2006 at 17:43:58 from (67.140.20.121):
I mounted an oil pressure gauge 100 psi as you guys suggested. The tractor is 1950 SA.
At start up it held 35 psi for about 30-45 min and slowly drop pressure, when the tractor was hot under load cutting heavy grass in 1 st gear at about mid throttle, she stayed at 13-18 psi for the next 3-4 hours. I'm wondering if this tractor is ready for an overhaul or is that an ok range and if I can hold off for awhile? I will do a compression test next.I run 30 wt. non-detergent per manual and change every 50 hrs. So is this a normal range?
Thanks,
Bob
