Re: McCormick 45 square baler
Posted by Fromjb2 on September 08, 2006 at 18:05:32 from (69.198.143.165):
In Reply to: McCormick 45 square baler posted by Ben Ford on September 07, 2006 at 21:09:18:
Hi Ben, tie the splicing knot like Janicholson says and we used to some grease to the knot and that would prevent it from sticking in the twine tension mechanism.
Good luck with the 45, I like many others rode
the twine box tying the missed knots.
JB2
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
