Farmall Tractors Discussion Board
Re: Power Steering for Super MTA (SMTA)?
Posted by john d on January 26, 2000 at 14:28:09 from (206.141.74.34):
In Reply to: Power Steering for Super MTA (SMTA)? posted by Marvin Boehm on January 26, 2000 at 13:14:39:
Behlen and Char-Lynn both made aftermarket systems for Farmalls. The Char-Lynn system has a pump that mounted on the left side of the tractor at the front of the governor box, and I'm pretty sure the rest of it was hidden under the hood. The Behlen units had a small pump that installed in the distributor drive, with a reservoir just ahead of the gas tank on the right side in the space where the extra gas tank for "distillate" tractors used to mount. The rest of the unit mounts above the gas tank and is installed by cutting the steering shaft in two. The Char-Lynn pump is noticeable as "non-original", but the Behlen steering motor is VERY noticeable! Both seem to work well, and should be available.
Since your SMTA should have live hydraulics, I'd think it would should be possible to use a feed off that pump to a Char-Lynn unit which would be out of sight. I haven't tried that, but I'll bet it could be done.
Post A Followup
: Re: Re: Power Steering for Super MTA (SMTA)?
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
