Re: 424 Distributor
Posted by genep on September 09, 2006 at 05:49:42 from (216.96.7.166):
In Reply to: 424 Distributor posted by Tim...Ok on September 08, 2006 at 13:39:39:
I'm not sure about the 424, but on the automotive units you can just remove the unit and put the points and rotor back in because the distributor plate isn't modified for the Pertronix.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
