Re: Super A Grill
Posted by Keith-OR on September 09, 2006 at 22:11:34 from (207.200.116.5):
In Reply to: Re: Super A Grill posted by SuperA-Tx on September 09, 2006 at 12:30:33:
Super-TX, the part of your bracket that is bent up is suppose to be flat and the bend below the two bolt holes is a 90 degree bend.Where you feel the raged edge a piece that is broken off bends down and has a threaded hole to hold the bottom part of your grill (thats the hole under crank access hole in bottom front of grill)
Maybe I can get a picture of my bracket tomorrow.
Keith & Shawn(son)
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
