Re: 400 - 3 different leaks
Posted by SDE on September 10, 2006 at 15:06:16 from (207.118.211.14):
In Reply to: Re: 400 - 3 different leaks posted by Janicholson on September 10, 2006 at 08:50:29:
THank you both. I tried too turn the single or double selector switch months ago. They had not been moved in so long that they were real stiff. I will check them again to see if I can move it some more. SDE
