Re: Purchased an M today
Posted by kfox on September 12, 2006 at 06:35:33 from (63.18.244.99):
In Reply to: Re: Purchased an M today posted by BDM on September 12, 2006 at 05:59:10:
The low range is a little lower than the factory gears, and high range is a little higher. My H will start out with a load in 4-H, and is almost as fast as the factory 5th gear. 5th gear is not effected by the 2 speed addition. ken
