Re: h carb settings
Posted by RustyFarmall on September 13, 2006 at 14:04:59 from (199.120.81.197):
In Reply to: h carb settings posted by tim coltman on September 13, 2006 at 13:50:15:
No such thing as a good place to start, the float settings are exact. Float level is 1 27/32" Float drop is 2 1/8". The main metering tube is static, it is not adjustable. If you are talking about the high speed idle, or load adjusting screw, it is turned in lighty until it seats, and then turned 3 full turns out. This is an initial setting, it may need to be turned out a bit more if the warmed up engine stumbles under a load.
