Re: connecting one way ram
Posted by old on September 13, 2006 at 16:03:02 from (4.245.5.218):
In Reply to: connecting one way ram posted by SDE on September 13, 2006 at 15:37:13:
First off to get it the way you want you just have to hook it up on the correct side of the hyds. But we could help you better if you told us what you are working on/ putting them on. One way cylinder work good for loader for the lift becuase of the weight of the loader pushs them back down but in a lot of things they will not do the job needed. More info please
