Re: connecting one way ram
Posted by CNKS on September 13, 2006 at 17:51:46 from (204.249.178.135):
In Reply to: connecting one way ram posted by SDE on September 13, 2006 at 15:37:13:
Not clear on exactly what you did. Is the cylinder attached to something? They go down by gravity thus have to have weight to pull them down. They also have to be vented, perhaps the vent is plugged. Or, as you say it could be an air lock.
