Re: Farmall A no start
Posted by RustyFarmall on September 14, 2006 at 12:14:53 from (216.248.75.143):
In Reply to: Farmall A no start posted by Bill in VT on September 14, 2006 at 11:53:40:
You didn't mention the contact points, if you haven't installed a new set, do so. It is also very easy to inadvertantly make a wiring just a little bit wrong and end up with wire or connection making contact with ground somewhere, and be really hard to find. It is possible that you need new spark plugs and wires but it would be unusual for all four plugs and wires to go completely bad all at the same time. Get out you magnifying glass and your fine tooth comb and see what you find. One more thing, sometimes new contact points will have a light film of oil on them, drag a clean and dry piece of paper in between the points to clean them.
