Re: Farmall A no start
Posted by Bill in VT on September 15, 2006 at 07:10:14 from (216.107.222.234):
In Reply to: Re: Farmall A no start posted by RustyFarmall on September 14, 2006 at 12:14:53:
Thanks! I'LL CHECK THE POINTS AND WIRING. Does the wire from the coil ground to the condenser? This in an H4 Magneto. Also, if I do the spark test (hold a wire against the frame?) and get spark, then most likely it's a fuel delivery problem? If no spark, then points? Is it possible for the engine to crank normally if there is a bad ground?? Thanks for all your help on this. Still learning a lot.
