Re: Super C Not Charging-Temp Fix?
Posted by John T on September 15, 2006 at 21:17:43 from (66.244.90.5):
In Reply to: Super C Not Charging-Temp Fix? posted by terryjd on September 15, 2006 at 19:26:28:
Terry, Assuming you have the light switch field current control system as opposed to a full fledged Voltage Regulator based on your post, it sounds like the problem is EITHER,,,,,the wires open between the gennys Field post and the light switch,,,,,,,,,,,,or the light switch doesnt have a good ground,,,,,,,,,,,or the switch could simply be badddddd. Does the switch have the L H B D positions??????? If so does it not charge in EITHER the L or H ??? If it dont charge in either Im back to the wires bad from the gennys Field post up to the switch or it dont have a good ground, cuz it ought to charge in either the L or H unless theres no ground on it at all or the wires open. It may be the case the switches resistor is bad (low charge) but Id still think the H (high charge) would work and if NEITHER does, Ima still back to thinkin the wires open from the genny or theres no switch ground. Yes its possible to jury rig a temp fix by dead grounding the gennys Field post butttttttt I would sure try n check the Field wire and the switch ground FIRST. With the Field dead grounded shes in the high max charge condition and after a longggggggggg time that way you could overcharge the battery and/or out gas n boil it over butttttttttttt that wouldnt happen in any matter of minutes, it would take a long time. If you wanna jury rig a temp fix so she will charge but at the lower safer rate, stick a 2 to 3 ohm power resistor in series in the wire from the Field post to ground butttttttttt I really dont think thats necessary for short term use. ALSO for a short term pull Id simply give the battery a good charge right before the pull and not even worry about running the genny, just use the stored battery energy to power the coil versus having to waste precious horsepower to power that dern genny runnin down the track. Other HP robbers are fan blades and water pumps (some use an electric pump when pulling). Best wishes n God Bless, let us know John T
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
