Re: Super C Not Charging-Temp Fix?
Posted by terryjd on September 15, 2006 at 22:05:26 from (69.159.71.212):
In Reply to: Re: Super C Not Charging-Temp Fix? posted by John T on September 15, 2006 at 21:17:43:
I do have a voltage regulater on the tractor, little square box. It has the F-Bat-L all in a row and Gen on it on the other side. The field that I grounded was the F on the regulator. Thats when the tractor started charging. The light switch does have a off-low-high.
First step in the guide is to turn on lights with tractor off- this shows discharge.
2'nd step-tractor running at least half set light switch to high run ground to battery post. Amp meter still showed discharge.
3'rd step- Jumper fld terminal to ground.
I jumpered the fld terminal at the regulator to ground on body then got a full 20 amp charge at amp meter. According to the chart this means light switch is bad. Almost sounds like I tested something wrong there.
If I shorted out the fld on the regulator and it charged maybe it is the regulator.
These electrics are simple enough but sure stump me. I put a new battery in the tractor so if I charge it up full it should get me through a couple of pulls then by the sounds of it. I never thought a battery would stay up that long.
