Re: Farmall 230 gear grinding problems
Posted by Hugh MacKay on September 16, 2006 at 14:53:43 from (209.226.247.15):
In Reply to: Re: Farmall 230 gear grinding problems posted by John in Red Hook NY on September 16, 2006 at 12:38:04:
John: The 230 doesn't have a transmission brake. Those are usually on larger tractors and designed so when clutch pedal is all the down, it applies a brake to stop the input gears of the transmission. The most common problems causing transmission not to stop I've seen are; pilot bushing, clutch disc not sliding on splined shaft. On new presure plates, sometimes the fingers are not adjusted equally. How long have you had this 230? Over the years a lot of folks changed the rear end-transmission oil from 90W gear oil to Hy tran. Hy tran is recomended for the newer tractors that draw their hydraulic oil from the rear end-transmission case. Those tractors for the most part have transmission brakes. Personally I wouldn't do that in these tractors. By these tractors I mean SA, SC, 100, 200, 130, 230, 140 and 240. The heavier oil will slow the input gears of the transmission down faster when you depress the clutch in neutral. You might try changing that oil before you go too far with this. I would refill it with gear oil 90W or heavier. The 230 does require Hy tran in the hydraulic system, but that is a completely separate compartment.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
