Re: 1086 oil pressure gauge
Posted by IaGary on September 17, 2006 at 04:42:54 from (69.63.5.240):
In Reply to: 1086 oil pressure gauge posted by Jim Johnson on September 16, 2006 at 23:20:31:
Jim
On the oil gauge most problems occur at the wire connections at the sending unit on the side of the motor.
Try cleaning all the wire connections for all the gauges and see what happens.
This usually fixes the gauges on mine.
Gary
