Re: STEERING on an H
Posted by TomH in PA on September 17, 2006 at 12:32:15 from (206.99.145.43):
In Reply to: STEERING on an H posted by Norm Glasr on September 17, 2006 at 11:48:03:
You can reduce the slop somewhat by tightening a pair of castle nuts on the shaft inside the steering box. Open it up (and clean out the grease if it's full). You should be able the see how to adjust it. And make sure the big plug in front of the box is tight against the steering shaft, it takes the end thrust.
