Re: Farmall 230 gear grinding problems
Posted by Marv on September 17, 2006 at 18:00:17 from (69.66.35.214):
John in Red Hook NY posted a message on 9/15 stating that he had a clutch problem with his 230. I'm having the same problem with my 230 which has been setting for a fer years. If indeed it is the pilot bushing or pilot bearing needing to be lubed, must the tractor be split to repair? There is a inspection hole underneath the belly of the tractor. Can the necessary repairs be made through this inspection hole?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
