Re: Farmall 230 gear grinding problems
Posted by Hugh MacKay on September 17, 2006 at 18:27:33 from (209.226.106.6):
In Reply to: Re: Farmall 230 gear grinding problems posted by Marv on September 17, 2006 at 18:00:17:
Marv: You'll have to split the tractor, the pilot bushing is in the end of crankshaft behind the clutch and presure plate.
Did you take note of what I told John about oil. I don't think your problem will be clutch sticking on shaft or fingers on presure plate being not equal, those two usually happen with new parts.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
