Re: IHC 1456 vibration
Posted by the tractor vet on September 17, 2006 at 18:13:44 from (75.24.23.154):
In Reply to: IHC 1456 vibration posted by GaryD on September 17, 2006 at 17:53:42:
Two things come to mind here (1) the Ft. damper has slipped and that is the first place i would go (2) the clutch is getting ready to come unglued. If the Ft. damper is realy oily it softens up the rubber between the outer damper ring and the inner hub or sometimes with age they just move and set up a vibration that sometimes will shake the filling out of your teeth . If left go it can break the crank. When i install a new damper i put two center punch marks on it , one on the hub and stright across from that one on the outer ring is a nother punch mark that was you can see if it moved.
