Re: Hand lift for an A?
Posted by gene bender on September 17, 2006 at 18:53:39 from (67.55.226.214):
In Reply to: Re: Hand lift for an A? posted by GTW on September 17, 2006 at 14:44:21:
The B had the same set-up but the arms were longer. The B also had two levers that each lever lifted seperate. The one you think for an A had the right lever as a master and the left one just balanced the cult so when the right lever moved it moved both left and right cults together. B and BN had similar set-ups. Now these lever set-ups were different than exhaust lift-all.
