Re: Coil Question
Posted by old on April 11, 2009 at 09:18:48 from (4.244.57.236):
In Reply to: Coil Question posted by Dunndan on April 11, 2009 at 09:14:33:
A coil will get pretty warm but should not get hot enough to burn you. That said there are some things that can cause it to do that. Points stuck closed, a shorted condenser, or a short in the wire going to the point will in fact cause a coil to get to hot and that in turn will burn out a coil
