Coil Question
Posted by Dunndan on April 11, 2009 at 09:14:33 from (75.90.0.196):
My Super A has been converted to 12 v. I run a negative ground. No ballast resister. I went to start this morning and after a few turns of the crank not even a single hit. I double checked that the switch was on and it was. Good fuel supply. Then I checked the coil wire. When I wiggled it I felt heat. The coil (12v internal resister) was so hot it almost burned a blister on my finger. The switch had been on about a minute, no more than 2. I assume that the coil should not be heating up like this. Am I correct? I am on my way to get a new one, but would appreciate any confirmation or information. Thanks.
