Re: Coil Question
Posted by JMOR on April 11, 2009 at 09:25:10 from (72.181.158.237):
In Reply to: Coil Question posted by Janicholson on April 11, 2009 at 09:14:33:
Dunndan said: (quoted from post at 12:14:33 04/11/09) My Super A has been converted to 12 v. I run a negative ground. No ballast resister. I went to start this morning and after a few turns of the crank not even a single hit. I double checked that the switch was on and it was. Good fuel supply. Then I checked the coil wire. When I wiggled it I felt heat. The coil (12v internal resister) was so hot it almost burned a blister on my finger. The switch had been on about a minute, no more than 2. I assume that the coil should not be heating up like this. Am I correct? I am on my way to get a new one, but would appreciate any confirmation or information. Thanks.
You say, "..coil (12v internal resister)...".
Exactly what coil do you use?
