Re: alternator charging sometimes
Posted by Bob on September 20, 2006 at 17:41:08 from (69.178.229.154):
In Reply to: alternator charging sometimes posted by Clint in Al on September 20, 2006 at 15:19:58:
Toss the GOOFY one-wire alternator in the trash, where it belongs, and get an original-type 3-wire Delco 10SI, and connect it like this:
If you'd like an "idiot light", simply OMIT the diode, and wire an indicator lamp with a #194 bulb, or a bulf of equivalent current draw into the SAME WIRE. The diode and the #194 lamp are direct substitutes for each other.
NOTE...
SOME "one-wire" alternators have the #1 and #2 terminals, shown in the photo, accessable, and functional.
In that case, you can retain the alternator you have, and connect the circuit to it's #1 "switched excite" terminal, and it will then begine charging at startup, with NO NEED to "GOOSE" the engine.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
