Re: Oil Pressure Guage - Adaptor Fitting
Posted by El Toro on September 21, 2006 at 03:34:07 from (205.188.116.133):
In Reply to: Oil Pressure Guage - Adaptor Fitting posted by Fiddling Man on September 20, 2006 at 19:08:13:
Home Depot carries a large assortment of brass
tube fittings. Is the oil line 1/4' copper tubing? If it is you probably need a compression fitting from 1/8" male pipe threads to
1/4" tube. You may need to cut off the old tube nut on the oil line with a tube cutter. Then install the new tube fitting on your new gauge
and then install the new tube nut on the oil line and then tighten. You can get them in straight
or in an elbow. Hal
PS: Take the old and new gauge with you.
