Re: M sputters on accelleration. Any ideas??
Posted by RustyFarmall on September 21, 2006 at 06:55:04 from (216.248.75.146):
In Reply to: M sputters on accelleration. Any ideas?? posted by Read Head on September 20, 2006 at 20:44:40:
Let me complicate things a bit. Your carburetor may be just fine. The symptoms you describe can also be caused by a weak ignition coil, improper ignition timing(too slow), or leaking intake manifold gaskets. One more thing to consider, these old Farmalls will all exhibit those same symptoms if the engine is not yet warmed up.
