Re: 2500A (574) won't stay running
Posted by Janicholson on September 21, 2006 at 12:25:45 from (199.17.6.122):
In Reply to: 2500A (574) won't stay running posted by chadd on September 21, 2006 at 06:34:44:
You could have a bad ballast resistor. (I do not know the tractor). Jump to the coil (supply side, not distributor side) with a wire from the non ground side of the battery and see if it will run that way. You may be getting only starter bypass voltage to the coil. JimN
