Re: 2500A (574) won't stay running
Posted by El Toro on September 21, 2006 at 16:53:08 from (152.163.100.65):
In Reply to: Re: 2500A (574) won't stay running posted by chadd on September 21, 2006 at 15:38:09:
You don't need a ballast resistor since your ignition system is 12 volts. They are required if your ignition is 6 volts and you are using a 12 volt charging system with a 12 volt battery. Have you checked the fire from that coil wire? Since your dad used the choke to coax the tractor home, I thought it was a fuel problem. Place you hand over the throat of the carburetor while someone makes an attempt to start the tractor. There should be good suction on your hand. This is how we used to check cars and trucks when we suspected a faulty fuel pump when they used mechanical fuel pumps. Since this happened all of a sudden I would bring No1 piston to TDC on the compression stroke. You need to pull the sparkplug near the radiator and hold your thumb over the plug hole while someone hand cranks the engine until you feel compression against your thumb. Then look for your timing mark and keep having the engine cranked until the timing mark is aligned with the pointer. Then pull the distributor cap and see where the rotor is pointing. It should be at the No1 plug tower. Hal
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
