Farmall Tractors Discussion Board
Re: Re: Alternator Conversion Wiring Diagram
Posted by Theman on January 27, 2000 at 09:23:19 from (204.149.23.2):
In Reply to: Re: Alternator Conversion Wiring Diagram posted by MrGadget on January 27, 2000 at 07:58:14:
I humbly offer another explanation. When you started the 350 with the battery, it excited the field of the alternator as soon as the alternator was turning enough rpm's. Once the field is excited in a spinning alternator, the output of the alternator is used to keep the field excited through its internal circuitry (diodes, etc). This happed way before you disconnected the battery cables. The "juice" needed to "make juice" is momentary, not constant.
Post A Followup
: Re: Re: Re: Alternator Conversion Wiring Diagram
