Farmall Tractors Discussion Board
Re: Alternator Conversion Wiring Diagram
Posted by MrGadget on January 27, 2000 at 07:58:14 from (216.170.12.242):
In Reply to: Alternator Conversion Wiring Diagram posted by Bob G. on January 27, 2000 at 05:26:41:
Bob G, I respectfully disagree with with your statement that "alternators need juice in order to put out juice".
My IH350 Utility has been converted to 12 volt with a GM alternator. Just a few weeks ago I needed to have both it and the 560 running at the same time, and only had one good battery, the one in the 350. I started the 350, and pulled the battery to use on the 560 (still has the standard generator system). The 350 stayed running on its own, without a battery.
Short of any other explanation, I believe this negates your statement.
Post A Followup
: Re: Re: Alternator Conversion Wiring Diagram
