Re: BobM Help :)
Posted by gene bender on September 22, 2006 at 10:24:15 from (67.55.226.214):
In Reply to: BobM Help :) posted by scotty on September 22, 2006 at 05:05:29:
Is the thing on top of the gen a reg or is it a cutout? If it is a cutout the field wire goes from the cutout to the terminal on the lite sw where the flat wire wound resistor is. This is for hi-charge and make sure the sw has a good ground thru the housing. There will be only one coil in the cutout if that is what it is. When you take that cover off if there is more than one coil and points you have a regulator. The witing harness for your B probably is for a cutout as that was standard.
