Farmall Tractors Discussion Board
Re: Re: Re: Alternator Conversion Wiring Diagram
Posted by Tom S. on January 27, 2000 at 10:46:04 from (209.214.112.209):
In Reply to: Re: Re: Alternator Conversion Wiring Diagram posted by Daniel on January 27, 2000 at 09:12:16:
I believe Dan has the correct answer guys! Tom S.
Incidentially, I am told the idiot lamp is used in place of a diode. It won't pass enough current back to energize the alt and cause the battery to discharge when the motor is shut down. Correction?
Post A Followup
: Re: Re: Re: Re: Alternator Conversion Wiring Diagram
