Farmall Tractors Discussion Board
Re: Re: Alternator Conversion Wiring Diagram
Posted by Daniel on January 27, 2000 at 09:12:16 from (152.163.206.176):
In Reply to: Re: Alternator Conversion Wiring Diagram posted by MrGadget on January 27, 2000 at 07:58:14:
Accutally, I believe you prove him right. How? The alternator does require voltage from the battery to start generating voltage. This voltage magnetizes the field, which is just a big electromagnet. Once the rotor turns in the magnetic field, it puts out its own voltage. After the tractor is running, you can remove the battery and the tractor will still run because the alternator is feeding itself. Don't ever try this in a modern vehivle though. The electronics, like the computer, can be damaged.
Just my input, Daniel.
Post A Followup
: Re: Re: Re: Alternator Conversion Wiring Diagram
