Farmall Tractors Discussion Board |
Re: Re: M has a locked up engine
Posted by Dick L on January 27, 2000 at 11:30:45 from (204.246.233.29):
In Reply to: Re: M has a locked up engine posted by Jeff W on January 27, 2000 at 07:38:46:
How long has it been locked up, set up, froze up, or what ever happened that caused it not to turn over? How are you going to use the tractor after you get it running? All of this would give insight as how to go about getting it turning over. If it has been set up for an extended period the cylinder walls will be pitted. I personaly think it takes less time to drop the pan and pull the head off so you can take the rod caps off and work on one pistons at a time than it does to spend days or weeks pouring oils into the plug holes. You can then see what your real problems are. As for jacking up the rear tire, you can get more tourque useing a pry bar on the ring gear through where you removed the starter. Good luck and I hope you have a warm place to work. Have fun
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
