Farmall Tractors Discussion Board
Re: M has a locked up engine
Posted by Jeff W on January 27, 2000 at 07:38:46 from (4.20.226.80):
In Reply to: M has a locked up engine posted by Ray on January 27, 2000 at 07:15:29:
I've had good luck, with 1/2 diesel fuel and 1/2
10w30. I had one that took a month to break loose.
I also take the vavle cover off and oil everything in there tap the ends of the rocker arm make sure the vavles aren't stick. I bent 3 push rods in a vac once not checking them. I pour the cyl. full
two or three times a week, Good luck Jeff.
Post A Followup
: Re: Re: M has a locked up engine
