Re: C engine will not die
Posted by russ hamm on September 23, 2006 at 10:14:25 from (63.245.179.200):
In Reply to: C engine will not die posted by Justin S. - TX on September 23, 2006 at 10:06:54:
justin, anyway you need to figure this out, because you have constant power to your points and they can get burnt while the tractor is just sitting. does it have the same push/pull switch as an h & m? one lead wire from the starter or solenoid should go to this switch hot and then the other to the distributor. that should be all, but i have not worked on any late tractors, so if it has a key switch then you will have to trace it down. good luck.
