Re: Jake F, T-Vet, or anyone- 1086 questions
Posted by P Backus on September 23, 2006 at 21:07:07 from (69.130.221.118):
In Reply to: Re: Jake F, T-Vet, or anyone- 1086 questions posted by JakeF on September 23, 2006 at 18:31:10:
Hi Jake,
The blowby was coming out in visible puffs, although it wasn"t
pouring out (like a DT466 powered tractor I"ve looked at in the
past) On my own DT 436 tractor, the blowby just kind of drifts
out rather than coming out in puffs. I think on this one the tube
comes out of the side cover (lifter cover), rather than out of the
valve cover, although I could be wrong. It was a DT414, not a DT
415.
It did seem like there was some play in the steering, so I"m sure
you"re right about that. Have you ever worked with those
aftermarket spindle arms (A&I, I think) that have tapered splines
that are meant to correct the loose spindle problem? Do they
work okay?
So which TAs will freewheel and which don"t? What the
difference?
Thanks for your help!
Paul
