Re: M temp gauge ?
Posted by Will Sickw on September 23, 2006 at 22:26:41 from (207.177.50.166):
In Reply to: M temp gauge ? posted by Granger on September 23, 2006 at 20:28:47:
It is probably the thermostat. Take the radiator cap off right after you start it and see what kind of circulation you have. If the thermostat is open you will see circulating water/antifreeze. If the thermostat is closed,as it should be with a cold engine there will be little motion.
