How to remove a inner brake plate / bearing retain
Posted by ENJ62 on September 25, 2006 at 07:47:57 from (64.200.84.78):
I have aSuper W4 and have to change the Bull shaft seals. I also want too true up the inner braking surface on the bearing retainer. I have been told by some this retainer just slides out and told by others you have to disassemble the transmission. Which is correct? If the latter is the case how do you remove the bearing seal?
Thanks for your help
ED
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
